1996 Plymouth Neon broken gas pedal switch??
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
CARDINALS1FAN
I have a 96 plymouth neon and i took my neice and nephew to the movies last night and noticed it was overheating, so i turned the heater on. temp went back down, a few mins past , driving at about 20 mph, I crossed the intersection and pressed on the gas to speed up... the gas pedal stayed on the floor, engine reving at high Rpms but no acceleration it just stayed at the same speed, immedaitly it jumped to high temp,(overheating), i freaked out and pressed the break, it took forever to slow the car, it slowed but not as usual. I used the E brake and put the car in Neuteral and guided the car to a parking lot. I turned the car off and left it there. The gas pedal is just laying there as if i broke it, no tension nothing.....I'm to afraid to try and start. and its sunday so triple towing costs. I searched the internet and found nothing so far.. if anyone could point me in the right direction that would be SO GREAT! the only thing i can think of is maybe the cable snapped? maybe the pedal switch? but if it did wouldn't the Rpm drop instead of rise???...... THANK YOU SO MUCH TO ANYONE THAT CAN HELP!
May 10, 2009 at 6:17 AM
ZACKMAN
  • 4,202 POSTS
Your accelerator cable snapped and broke, probably really close to the throttle body. One of the cable string may have jammed the throttle to wide open causing the high revving. That had happened to me a couple of years ago on my Cirrus.
But the does not explain your first overheating issue. It is quite possible that your engine coolant temp sensor is faulty causing the radiator fans not turning on at the right temperature. That may explain that as soon as the engine revving way high, the gauge went up overheating.
May 10, 2009 at 9:05 AM
