1997 Plymouth Neon Bleed the brake system
55,528 MILES • 4 CYL • FWD • AUTOMATIC
BM82361
I replaced the power booster, front pads and rear pads. i then tried to bleed the system but afterwards the brake pedal has to pushed real hard before the car stops, what did i do wrong?
Sep 5, 2010 at 8:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
what do you mean you tried to bleed them? is fluid getting to all wheels when you bled it? did you check to ensure brake fluid is full?
Sep 5, 2010 at 9:41 AM
