1996 Plymouth Neon remove harmonic balancer
1996 PLYMOUTH NEON
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
SC58
  • 9 POSTS
How do you remove the harmonic balancer from a 96 neon . I tried use a 3 prong puller with a pin insert in the hole . but am bending the pin.
Aug 17, 2009 at 4:54 AM
THIS IS MIKE
  • 686 POSTS
After removing the bolt, spray with WD40 or penetrating oil. Once you have installed the puller and have applied pressure try tapping the Balancer with a mallet or hammer to let the oil help. Sometimes they get stuck on there pretty tight.
Sep 4, 2009 at 5:06 AM
