1996 Plymouth Neon Output Shaft Bearing
DADDYO44907
Transmission problem
1996 Plymouth Neon 4 cyl Front Wheel Drive Automatic
Can you tell me what the Torque should be for the Output Shaft Housing. I am about to replace the bearing and seal.
Thank You.
David
Apr 30, 2010 at 2:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2092.jpg
Apr 30, 2010 at 3:04 PM
DADDYO44907
Now I am told it is the Transaxle Extension Housing cover. I need the torq for the 4 bolts that hold the cover. The Output Shaft bearing is being replaced.
Apr 30, 2010 at 3:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the list above contains all torque specs needed for overhauling your vehicle's transmission. the extension housing bolt is listed 4th down on the list.. 21 Ft. Lbs.
Apr 30, 2010 at 3:13 PM
