I changed the switch and the check engine light is still on, how do I fix this?
Feb 25, 2010 at 1:52 PM
BLUELIGHTNIN6
✓Experienced Mechanic
if the siwtch has been replaced then you will need to delete the trouble codes with a diagnostic scanner. if the code does come back after that, check for faulty wiring to the switch
