When setting the crank and cam timming on there marks is it possable to have the engine 180 degrees out of time on the crank I just want to make sure when I put the crank on its mark that it will always be on the compression stroke. I had to order a new head I got the old one off and #1 piston is at top and the crank is on its mark but could it be on its mark and on the exhaust stoke at the same time or do I have it right ???
Jan 4, 2010 at 12:21 AM
