1995 Plymouth Neon reverse light switch
16,000 MILES • 4 CYL • 2WD • AUTOMATIC
JJOSEPH1010
When backing up, my reverse lights don't light up, but if I play with the shifter I can get them to work, sometimes.
Also My instrutment cluster goes dead some times. Maybe a loose connection in dash?
Aug 27, 2010 at 3:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
instrument cluster is common problem, will need to remove cluster and resolder the back of the circuit board where you will find some broken lines.
the back up switch is probably at fault for the back up lights or the wiring going to it.
Aug 27, 2010 at 10:45 AM
