1995 Plymouth Neon OIl leak
1995 PLYMOUTH NEON
135,000 MILES • 4 CYL • FWD • AUTOMATIC
86TRANS_AM
I have a "95 Plymouth Neon with the 2.0 SOHC. I have oil leaking out around the transmission and engine when i drive for extended periods of time. Short trips don't make it leak oil. I was told it could either be the rear main seal or the oil pressure sending unit. the entire back of the motor is cvered in sludge from a leak some where.
Jul 25, 2009 at 1:37 PM
DLM
I had the same problem on a 95 neon and thought it was rear seal, oil sending unit, cam sensor but it turned out that the head gasket was leaking oil and only did it on a long haul at hiway speeds. Replaced the head gasket and fixed the problem. Beware it is not an easy fix.
dlm112254@yahoo.com
Jul 25, 2009 at 1:58 PM
