1995 Plymouth Neon jumpy speedometer
150,000 MILES • 4 CYL • FWD • AUTOMATIC
PYNCHON
I am not sure what is going on with my car....all of a sudden when I was driving my speedometer went from saying I was traveling at 55 mph to 0 mph. However, the car did not lose power. It also rebounded and bounced up and down for a bit then settled down, ran fine for awhile ...then it started jumping again. Is this a loose connection? a sensor? or just something as simple as a fuse? I just had the rear main seal replaced and with it I had 2 of the transmission mounting bolts replaced. In fixing that could they have inadvertently caused this problem.
Jun 22, 2010 at 5:10 PM
BILLYMAC
  • 2,204 POSTS
yes check the speed sensor wires on the trans
Sep 28, 2010 at 11:10 AM
