1995 Plymouth Neon blows fuel pump fuse
MYGRANTJL
Electrical problem
1995 Plymouth Neon 4 cyl
It blows fuse while driving. What can I do to locate or isolate problem.
Aug 18, 2009 at 4:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you must have a short somewhere. start by checking aroung the wires that are under the air intake hose that runs across the driver side of the motor. sensor wires are close to heater plumbing and would short other systems also look for wires were o2 sensor connect to other wires. most common is the o2 sensor wiring comes in contact with the exhaust and shorts out. fuel pump is on same circuit as the o2 sensor.
Aug 18, 2009 at 5:41 AM
