1994 Plymouth Laser engine stalling
57,000 MILES • 4 CYL • FWD • MANUAL
SKRIPPINLASER35
The car starts and idles perfect. It will run completely fine until it is warmed up. At this time it will idle rough,low, and/or stall when slowing down for a stop sign and light. It has done it before in the past but now it is every time i drive the car and it is my main transportation.Eventually if i give the car gas repeatedly i can get the idle to even back out.
Nov 28, 2009 at 8:21 AM
  • 75,988 POSTS
Check the idle speed control motor, volume airflow sensor, throttle position sensor, EGR and PCV valves.
Nov 28, 2009 at 9:36 PM
