1993 Plymouth Laser Service Engine Light
154,000 MILES • 4 CYL • AWD • AUTOMATIC
ALLYNRITTHALER
The Service Engine Light is on but the car seems to be running fine. I took it to a shop to have it scanned and the scanner said 211 undocumented code. The mechanic can't find an answer. Any ideas?
May 28, 2009 at 2:42 AM
JDL
  • 16,098 POSTS
Hello, did you try to access codes, yourself, by cycling the ignition switch? I just wondered what that might show, if anything?
May 28, 2009 at 2:53 AM
ALLYNRITTHALER
I don't have a problem accessing codes. I want to know what code P00211 means.
Jun 9, 2009 at 10:29 AM
JDL
  • 16,098 POSTS
sorry, I was asking for the two digit code? P0211 is injector circuit malfunction, cylinder 11.
Jun 10, 2009 at 1:16 AM
ALLYNRITTHALER
How can that be? It's only a four cylinder engine.
Jun 10, 2009 at 9:56 AM
JDL
  • 16,098 POSTS
Yes, does the two digit code show anything different? I don't know why you would get that code on a 4 cylinder engine.
Jun 11, 2009 at 1:43 AM
