Crank position sensor replaced with a new one in my 1993 plymouth laser. Several times now the engine would turn over but not engage. Had it towed to the garage thinking the new sensor may be defective but after tow truck left garage the car would start up. Could the new sensor be faulty but work intermittently? Could it be the engine control module/computer? Does the garage need the problem to manifest itself again before they can properly diagnose the problem? The fuel pump was checked and it is fine.
Nov 21, 2009 at 4:01 PM
