1991 Plymouth Laser trans shifts hard down shifts even hard
1991 PLYMOUTH LASER
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
ECLIPSD
I have a 1991 plymouth laser rs turbo. It has an automatic transmission(f4A33-1) the car shifts very crisp/hard and down shifts even harder. the shift from 2nd to 1st can be brutal and clunks. The fluid has been changed. For the first 5 miles it shifted perfect but then
back to the same thing.Please help
Feb 8, 2010 at 7:42 PM
2CARPRO JACK
  • 11,533 POSTS
Could be a valve body issue.Is the check engine light on? sometimes if the light is on, the trans will go into a"limp" mode which will affect shifting.Othersie you may want to have atrans shop look at it for you to see what they think.Have you replaced/checked the motor mounts? if the mounts are bad it can make the trans feel like it is shifting harder than it really is.
Feb 10, 2010 at 7:38 AM
ECLIPSD
Thank you for responding to my question.A transmission shop scanned for codes and they said they got nothing from it. They said to just buy a used transmission and swap out. I cant afford to do that right now Im trying to figure out the problem by blogs. The transmission looks shiny and new. I know that does not mean that it is but I think it could be something simple. What do you mean by valve body? How can i check this? Will check the motor mounts but the downshift to first can be violent and not normal it sometimes feels like it almost stops the car.
Feb 18, 2010 at 3:37 PM
2CARPRO JACK
  • 11,533 POSTS
in a 91, that will most likely be a valve body problem.You will need the proper pressure gauges to test the line pressures.The valve body is the part inside the trans that contains the hydraulic valves and any electric solenoids that make the trans work.I understand the money end of your situation, but I would call a few other trans shops and ask if they can actually diagnose it.They will have the proper tools for something like this
Feb 18, 2010 at 7:42 PM
ECLIPSD
Thanks, I will call around and check back thanks for a quick response
Feb 18, 2010 at 11:28 PM
2CARPRO JACK
  • 11,533 POSTS
youre welcome
Feb 19, 2010 at 7:37 AM
