1989 Plymouth Horizon,30,000mi. conking out aft. starting
1989 PLYMOUTH HORIZON
LINDA JARDEE
Help. Elderly mother has a 1989 Plymouth Horizon with approx. 30,000 mi. on it that recently had a tuneup with about 3 sparkplugs & wires replaced. Since the tuneup; I took the car for a longer drive. It sat outside (very mild weather) for about 2 1/2 hours. When I went to start it, it started right away, but conked out immediately at least 2-3x before it continued to run. Didn't do this prior to the tuneup. Any suggestions or advice on why this would be conking out when starting it? Thanks.
Jan 7, 2007 at 12:26 PM
SERVICE WRITER
  • 9,123 POSTS
Why only 3 plugs and wires? :?
Check the connections to both ends of all of the ignition wires and be sure they are seated on all the way. May or may not be related to the tune up.
Jan 7, 2007 at 1:14 PM
