Anyone know of any common issues with lopey idle on this vehicle. Been doing it for years with many individuals and shops trying to smooth out the idle and stop it from dying at stop lights. When cold it dies at idle no matter what's been done. When heated above normal operating temperature the problem almost disappears but comes back with intermittent lopey idling. Almost to the point of dying and just barely "hangin on." Any ideas on what to check first? Fuel pump/pressure is fine, new gas, new plugs, new wires, new distributor cap/rotor. Idle is controlled via computer so it's not adjustable to my knowledge. Could it be a bad O2 sensor or maybe a leaking vacuum line? Any good/simple ways to find vacuum leaks?
Apr 13, 2009 at 12:39 PM
