1985 Plymouth Horizon engine jerks badly when accelerating
81,725 MILES • 4 CYL • 2WD • MANUAL
AK_SPRAYBERRY
I have an '85 Plymouth Horizon that has just recently began to "buck" severly when I accelerate from first thru 4th gears. It feels like the enmgine is trying to cut-off. I have replae the distributor cap and rotor and the plugs and wires. Any suggestions?
Oct 25, 2009 at 11:52 PM
  • 75,988 POSTS
Check and test the following:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Oct 26, 2009 at 12:22 AM
