1970 Plymouth Fury shiftingon a 904 Tourqueflite
1970 PLYMOUTH FURY
10,000 MILES • V8 • 2WD • AUTOMATIC
POSS' 51KUSTOM
I Actually have a 51 Plymouth Concord, not listed on your site. I have installed a new 904 trans, street and strip model. It shifts fine except when going from 2 to 3, it doesn`t shift untill about 3200 rpm.I beleive I have the trans pressure arm adjusted right. I have it that at full throttle, the trans arm is almost to the rear of it`s travel. Is this the correct way to adjust this arm , or am I doing something wrong ? thanks
Aug 20, 2009 at 12:52 PM
HMAC300
  • 48,601 POSTS
shifting from 2 to 3 at 3200 is ok if you are above half throttle. If not then you need to readjust your rod...
Nov 13, 2009 at 1:03 AM
