Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Plymouth
Colt
Engine
Crankshaft
Rear Crankshaft Seal
Replace/Remove
1993 Plymouth Colt Rear Main Seal
1993 PLYMOUTH COLT
124,000 MILES • 4 CYL • 2WD • AUTOMATIC
MRSCARLETON
MEMBER
1 POST
How do I replace the rear main seal?
Jan 19, 2009 at 7:14 AM
BMRFIXIT
Experienced Mechanic
In general you need to determine witch one do u have
if its one piece removing the tranny will allow you an access to remove and replace the seal
if two pieces removing engine and oil pan
Jan 19, 2009 at 8:10 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine — Stall at Idle
