1993 Plymouth Colt Fuel Pump
1993 PLYMOUTH COLT
160,000 MILES • 4 CYL • 2WD • MANUAL
JOE.O.NELSON
The fuel pump on my 93 plymouth colt (1.8L sedan) has stopped working. I replaced the fuel filter. Where is the fuse which controlls the fuel pump? The fuel pump fuse is not listed with the fuses in the engine compartment. So how do I tell which fuse controlls the pump?
Nov 29, 2008 at 9:12 AM
Its not listed bcuz it doesn't have one -the ECM relay is the one that powers the fuel pump and injector-look for power at black and red wire on the injector harness-no power there -points to a bad relay
Nov 29, 2008 at 9:28 AM
