Check the fuses and and relay under the hood, fuse box, if you can scan for codes. Check coolant temperature sensor should be 7000-12000 ohms at 70 and go down as temperature rises.then check crank and cam sensors connections do a wiggle test on them to see if makes a difference. Finally try resetting your security system if no manual look online for you vehicle how to reset.
Mar 20, 2016 at 8:08 AM
