My AC-Haeater only works on High setting. How do I fix this?
CTDESIGNS
1997 Plymouth Breeze - mileage 157,552:
I actually have a couple of problems.
Number one, The temperature of my heater/air conditioner works great, but it only turns on in the high position.
Question number two: My headlights only work in the LOW BEAM setting. When I switch them to HIGH beam, the lights turn off.
What can I do?
Jun 8, 2006 at 7:09 AM
KILLZODIAK
  • 13 POSTS
for the lights you might want to try a new bulb. if the high beams still dont work then it might be the switch that needs to be replaced. as for the ac im not sure what to do.
Jun 8, 2006 at 7:18 AM
SCFAMILY
  • 6 POSTS
See this thread if your blower motor only works on high -
[url]https://www.2carpros.com/forum/1994-plymouth-voyager-se-30l-blower-vt15802.html[/url]
In the Breeze, the blower motor resistor should be located in the passenger compartment, passenger side, under dash behind the plastic kick plate there.
Aug 22, 2006 at 11:51 AM
MIKEYBDMAN
  • 623 POSTS
[quote:b3ed86980e="ctdesigns"]1997 Plymouth Breeze - mileage 157,552:
What can I do?[/quote:b3ed86980e]
Your headlights have a seperate fuse for each light bright and dim. It also has a Headlamp Delay Relay. But the switch itself would be where I would start if the bulbs and fuses are good.
Aug 22, 2006 at 12:14 PM
