1999 Plymouth Breeze Check Engine Light
TIAWRIGHT
I have 99 Plymouth Breeze and it has 144,000 on it. My check engine light came on. I went to autozone, got it tested and it was a gear 1 incorrect ratio. Do I need a transmission?
Sep 23, 2007 at 11:15 PM
SERVICE WRITER
  • 9,123 POSTS
You mean they checked the codes, what code number?
Sep 26, 2007 at 4:31 AM
TIAWRIGHT
[quote:40bf53cae0="Service Writer"]You mean they checked the codes, what code number?[/quote:40bf53cae0]
p0731, p0700
Sep 26, 2007 at 8:48 AM
SERVICE WRITER
  • 9,123 POSTS
PO700 "may" be a bad (EATX) Electrononic Automatic Transmission Controller.
PO731 is more complicated and is an intermittant problem. It is usually caused by intermittant hydraulic seal leakage in the clutch and or accumulator circuits.
After doing a little research, it seems that an input shaft speed sensor may solve the problem.
Sep 26, 2007 at 9:52 AM
Suggested Repair
Do not assume a full transmission replacement yet. P0700 may indicate a faulty EATX electronic automatic transmission controller. P0731 is often intermittent and can be caused by hydraulic seal leakage in the clutch or accumulator circuits; an input shaft speed sensor may also resolve it.
Conversation Summary
The owner of a 1999 Plymouth Breeze with 144,000 miles reported a check engine light. An AutoZone scan showed a gear 1 incorrect ratio, and the owner asked whether a transmission was needed. The codes were identified as P0731 and P0700. The expert said P0700 may indicate a bad EATX controller, while P0731 is an intermittent fault often caused by hydraulic seal leakage in the clutch or accumulator circuits. Research suggested that an input shaft speed sensor may solve the problem.
