Breeze horn and cigarette lighter
JMARKSR
The horn and cigarette lighter on my 1999 Breeze, 3.3L, both stopped working at the same time. The fuses in the engine compartment are all OK. Are the horn and lighter circuits connected to each other?
Jan 14, 2007 at 11:43 AM
SERVICE WRITER
  • 9,123 POSTS
Left front corner of the engine compartment you will find a fuse box, in that fuse box you will check fuse #8 which is a 20 amp fuse. That fuse does indeed handle the horn relay, cigar lighter and your power amplifier. :wink:
Jan 14, 2007 at 12:41 PM
JMARKSR
thank you
Jan 14, 2007 at 12:59 PM
SERVICE WRITER
  • 9,123 POSTS
Ubetcha
Jan 14, 2007 at 8:18 PM
STRATUS98
  • 96 POSTS
3.3 liter wow.... also their is a fuse in the side panel next to the dash that could also be your problem.
Jan 15, 2007 at 7:06 AM
SERVICE WRITER
  • 9,123 POSTS
HAH! I was looking at the PDC location. :oops:
Thanks stratus98!
I knew someday I'd make a mistake 8)
Jan 15, 2007 at 7:13 AM
