1999 Plymouth Breeze Blower High Only
J SHOCIK
I have a '99 Plymouth Breeze that the heater blower works only on high. I searched other questions & found the blower resistor is possibly bad. My question is where is the blower resistor on this car? Thanks, John
Jan 31, 2007 at 6:55 AM
BOOTDOG
  • 665 POSTS
it will either be located near the blower motor, or behind the dash, in the middle, underneath the windshield. good luck.... hope this helps
Jan 31, 2007 at 10:23 AM
J SHOCIK
The info helps a lot, although it sounds like the job will be a PITA!!.. Thanks bootdog, John
Jan 31, 2007 at 8:53 PM
Suggested Repair
Locate the blower resistor near the blower motor or behind the dash in the center under the windshield, then inspect and replace it if the heater blower runs only on high.
Conversation Summary
The owner of a 1999 Plymouth Breeze reported that the heater blower works only on high and asked where the blower resistor is located. The expert said it is either near the blower motor or behind the dash in the center under the windshield. The owner thanked the expert and noted that the job may be difficult.
