97 Plymouth Breeze code P1768
DAWG4015
97 Breeze check engine light on Checker did diagnostics that gave a P1768 code. It also stated relay always off, relays are stuck open, fuel system 1 closed loop. What does all this mean. Thank You
Sep 25, 2007 at 9:59 AM
JWALTH02
  • 180 POSTS
This is an explorer sport track correct? This is what I found on that code, but not too sure if it's your exact problem.
P1401=insufficient EGR flow-DPFE sensor code-
Check the 2 hoses connecting the exhaust manifold to the dpfe sensor.
pull them off and look real closely for holes blown out.
Jul 11, 2007 at 6:00 PM
