2000 Plymouth Breeze water pump
168 MILES • 4 CYL • FWD • AUTOMATIC
JIM00_1999US
How long a job is this and should timing belt be done due to coolant leak. a new belt was put on 5 months ago.
Nov 5, 2008 at 1:37 AM
DAVE H
  • 13,383 POSTS
The book times on remove and replace are 3.5 hrs for a 2.0L engine and 4.2 hrs for the 2.4L engine .. i would personally replace belt at same time to be on the safe side ?? other tech's may tell you different ?? it is upto you at the end of the day to make this decision
Nov 8, 2008 at 2:57 AM
