2000 Plymouth Breeze OIl In the Spark plug boots
NISHAS23
Engine Performance problem
2000 Plymouth Breeze Automatic 131000 miles
I was driving and my car just all the sudden stopped when i tried to accelerate a little more one the highway. I looked under the hood and seen oil in the holes where the spark plugs are. I think the valve cover seal is leaking. no the car wont start. It tries but it wont turnover or fire. I want to know exactly what seems to be wrong and what can be done to fix it. Is it expensive?
Jul 29, 2009 at 6:50 AM
SMILESILLLY
I had the same issue with my 2000 Breeze, I would suggest having your timing belt replaced as well as maybe your tensioner and valve cover gasket. I had the exact same problem, the car stopped while I was driving and there was oil in one of my spark plug boots. It's not an interference engine so your damage should be minimal. It should cost at tops up to about $180 in parts, not including labor.
Jul 30, 2009 at 5:50 AM
