Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Plymouth
Breeze
Engine
Block
Freeze Plug
Replace/Remove
2000 Plymouth Breeze Freeze Plugs
2000 PLYMOUTH BREEZE
133,630 MILES • 4 CYL • FWD • AUTOMATIC
KSTWINMOMMY
MEMBER
1 POST
I need to know if the freeze plug blowing can be a result of an improper head gasket and radiator replacement from a few months ago?
Sep 15, 2009 at 5:10 AM
Experienced Mechanic
They have nothing to do with each other. A bad freeze plug is usually the result of rust and corrosion from not servicing the cooling system.
Dec 19, 2009 at 6:11 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
