2000 Plymouth Breeze engine stops will not start
2000 PLYMOUTH BREEZE
138,000 MILES • 4 CYL • FWD • AUTOMATIC
PJAMESRT
had tansmission down shift ruff run ok. next time drove car engine shut down check engine light came on, and would not restart. let set for 15 mins engine started. obd code po0700. clearded code car run fine next two days . then, check oil light comes on engine shuts down will not restart. let sit 15 min engine started no oil light. drove 3 miles oil light comes on engine shuts down. check for codes nune stored after letting car set starts again. any suggestions.
Thanks ,
P C james
Mar 23, 2010 at 12:09 AM
LEGITIMATE007
  • 5,121 POSTS
I would check the crank sensor. as this does not usually show a code when partially faulty
Mar 23, 2010 at 1:09 AM
LEGITIMATE007
  • 5,121 POSTS
po700. transmission control module at fault, not sure its because something else like the crank sensor caused it or not. you can only find that out with a high end scanner. but still check the crank sensor
Mar 23, 2010 at 1:12 AM
