2000 Plymouth Breeze
PHYLLIS627
  • 2000 PLYMOUTH BREEZE
Where do you put the steering fluid in on a 2000 Plymouth Breeze?
Saturday, November 21st, 2009 AT 3:52 AM
CARADIODOC
  • 34,365 POSTS
Why do you think it needs power steering fluid? What are the symptoms? The fluid goes in the same place you check the level; under the cap marked "power steering fluid". If it's low, there is most likely a leak that needs to be fixed. This fluid is also normally checked by whoever changes your oil. It's part of the service when it's done by professionals.
Caradiodoc
Saturday, December 12th, 2009 AT 6:59 AM
