1999 Plymouth Breeze Power Steering
1999 PLYMOUTH BREEZE
150,000 MILES • 4 CYL • FWD • AUTOMATIC
JTITEL
Ok,
So a couple weeks ago my power steering went out. Now as fun as it is to drive like this... I need it fixed. I replaced the power steering belt and power steering pump. Neither helped. I was told that rack and pinion is next... I need to know is there a way of telling that is what is wrong? And how hard is a rack and pinion to put in yourself?
Nov 18, 2008 at 6:23 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
As you have already replaced the pump, the rack is all that is left apart from the pressure and return hoses. Do you have a leak in the system? is the pump making a loud noise when the steering is on full lock? I will check the procedure on doing the rack and re post soon.
Mark (mhpautos)
Nov 18, 2008 at 10:04 AM
JTITEL
nope no noise at all... just real hard to turn... thanks for your help
Nov 19, 2008 at 9:12 AM
