1999 Plymouth Breeze pcv valve
173,000 MILES • 4 CYL • FWD • AUTOMATIC
NANCYYZ123
Hi, my pcv valve broke off in my valve cover. There is a metal piece it screws into that i pulled out of the valve cover but i can't get the broke piece out. I don't know what the metal piece in the valve cover is called in order to get a replacement part it is the shape of a donut round with a hole in it that is threaded so the pcv vale can screw into it. Can you help me figure out what that part is so i can replace it please?
Thank You very much,
Nancy
Sep 28, 2010 at 1:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you mean the part that broke was made as part of the valve cover? it would be easiest just to replace the valve cover with a used cover from a local salvage yard
Oct 21, 2010 at 2:18 PM
