1999 Plymouth Breeze odometer reads door, door locks auto l
1999 PLYMOUTH BREEZE
188,000 MILES • 4 CYL • 2WD • AUTOMATIC
WRBUTLER
Once the vehicle being driven, the doors begin to lock multiple times and the odometer flashes "DOOR". The dome light stays on. The drivers door switch has been replaced and all of the other door swithch connectors and wires have been checked. Wires to the fuse block have been checked and all fuses are good. This is intermittant as the problem is not continually occuring but happens many times, everytime the vehcile is driven.
May 21, 2009 at 10:56 AM
BMRFIXIT
  • 19,053 POSTS
Check BCM DATA
and check door switches
one is opening and closing
spray WD 40 in it close and open door few time
most common is driver door, I would do them all
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 23, 2009 at 5:35 AM
