1999 Plymouth Breeze codep1495
156,121 MILES • 4 CYL • 2WD • AUTOMATIC
STEPHENROD
i just changdg the computer on my breeze cause #3-4 injectors were not working. fiexd that and now i have a code p1495 and can not figure out how to check or repair it. i've run out of ideas. any info would be helpful thanks in advance.
Jun 10, 2010 at 8:41 AM
  • 75,988 POSTS
P-1495 LEAK DETECTION PUMP SOLENOID CIRCUIT
POSSIBLE CAUSES:
FUSED IGNITION SWITCH OUTPUT OPEN
LDP SOLENOID CIRCUIT SHORT TO GROUND
LDP SOLENOID CONTROL CIRCUIT OPEN
LDP WIRING HARNESS INTERMITTENT FAULT
WIRING AND CONNECTORS VISIBLY DEFECTIVE
LEAK DETECTION PUMP DEFECTIVE (LDP SOL CKT)
PCM DEFECTIVE
Jun 10, 2010 at 11:02 AM
STEPHENROD
But how do I check the pump soleniod and other items
Jun 10, 2010 at 12:39 PM
