1999 Plymouth Breeze BLOWING FUSE
1999 PLYMOUTH BREEZE
87,567 MILES • 4 CYL • FWD • AUTOMATIC
CHITIMACHA
When you try to start the car the 20 amp Ignition/fuel starter fuse blows. At first it would do it occasionally but now most every time it does it and won't allow the starter to turn over. Does anyone know if this is common to the Plymouth Seabreeze? Where should I start to look for a short?
Dec 3, 2007 at 11:29 AM
BMRFIXIT
  • 19,053 POSTS
[quote:7c1379133b="chitimacha"]Electrical problem
1999 Plymouth Breeze 4 cyl Front Wheel Drive Automatic 87,567 miles
When you try to start the car the 20 amp Ignition/fuel starter fuse blows. At first it would do it occasionally but now most every time it does it and won't allow the starter to turn over. Does anyone know if this is common to the Plymouth Seabreeze? Where should I start to look for a short?[/quote:7c1379133b]
change the starter check the wiring around it
Dec 3, 2007 at 11:45 AM
