1999 Plymouth Breeze 2.4 Coil only firing cylinder # 1 &amp
1999 PLYMOUTH BREEZE
100,000 MILES • 4 CYL • FWD • AUTOMATIC
MAMERZ
I changed coils and same problem.
Mar 31, 2010 at 10:42 AM
LEGITIMATE007
  • 5,121 POSTS
what exactly is your situation?
Mar 31, 2010 at 11:39 AM
MAMERZ
Engine is only running on two cylinders. No fire from the #2 & #3 coil terminals.
Mar 31, 2010 at 11:49 AM
LEGITIMATE007
  • 5,121 POSTS
I suspect the computer needs to be flashed or the crank sensor needs replacement
Mar 31, 2010 at 5:19 PM
MAMERZ
I guess you pay $10.00, you get a $10.00 answer. I could have gotten that answer from 25 idiots on Yahoo answers.
Apr 1, 2010 at 8:26 AM
LEGITIMATE007
  • 5,121 POSTS
ok, so what did you expect. I told you whats wrong with it. I can t fix it from here.
Apr 1, 2010 at 8:42 AM
EDONOVSKY
how does one (flash) the computer? i replaced my crank sensor and now my engine is missfiring very badly. does anyone have an idea?
May 9, 2010 at 9:20 AM
