1999 Plymouth Breeze
15,400 MILES • 4 CYL • 2WD • AUTOMATIC
AMBEREYES2290
I was driving my car a few days ago and it died as I came up to the light. It coasted through the intersection and I had to have it pushed into a parking lot. My dad and I borrowed a coder machine from the local auto store. The machine said that there was an intermittent loss of either the Camshaft or Crankshaft and that it needed either a new sensor or new timing chain. What is the estimated cost of that? I am a college student and can not really afford a lot in repairs but I need my car to get to campus and work.
Nov 12, 2009 at 12:31 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect timing belt
and should check that before any more cranking
as you may end up with a bent valve
if it hasn’t happened yet
its about $300 to do the timing /water pump
crank sensor is about $150
all parts and labor
Nov 12, 2009 at 12:45 PM
