1999 Plymouth Breeze
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
BETITOJR1
I drained the antifreeze from the radiator by unscrewing the drain valve at the bottom of the radiator. When I try to tighten it back, Im having a hard time doing so. I keeps slipping. Is there a ceratin way to tighten it?
Nov 9, 2008 at 12:31 PM
DAVE H
  • 13,383 POSTS
sounds like you have cross threaded it .. you will have to re-tap (re-thread) the hole .. if you have no experience of this your best bet is a mechanic ..
Nov 12, 2008 at 1:12 PM
