my car started to jump rpms and then it just wouldn't shift what could be the problem
Nov 19, 2009 at 8:28 PM
✓ASE Certified Mechanic
When you say it started to jump, was the trans slipping? Also, has the check engine light come on? There is a trans module that controls it and if it is causing the problem, the light should be on.
Let me know what you find.
JOe
Dec 20, 2009 at 1:10 AM
