1998 Plymouth Breeze rough idle and stalls when you come to
1998 PLYMOUTH BREEZE
294,000 MILES • 4 CYL • FWD • AUTOMATIC
DEAN WALLAGE
when in park idles a little low but you can here a miss,compression is 185psi,new plugs and wires and coil,fuel pressure is 42psi when running and 10 psi when you turn the key on
Mar 8, 2009 at 5:20 AM
Recheck the fuel pressure when you turn key to run and also while its running again then get back.
Mar 8, 2009 at 11:58 AM
