1998 Plymouth Breeze rough idel
HDBIKER
Engine Performance problem
1998 Plymouth Breeze 4 cyl Front Wheel Drive Automatic
my car runs great but when the ac is on and i come to a stop the rpms drop down to 500 to 200 sometimes cuts off
Jul 18, 2008 at 11:46 AM
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
If the light is blinking, it means possible damage to the converter...service it right away!
Check the idle air control valve...bolted to the throttle body.
Jul 18, 2008 at 11:56 AM
