1998 Plymouth Breeze Oxygen Sensor
14,800 MILES • 4 CYL • FWD • AUTOMATIC
KMELLITO
Can you show me how to install an oxygen sensor?
Jun 20, 2009 at 4:48 AM
OBXAUTOMEDIC
  • 3,711 POSTS
I can tell you how I cannot show you how. It is very easy to do.
Depending on where the sensor is located there are 2 ways to remove them.
One is by using a special tool, O2 Sensor Socket and the other is using a regular wrench.
Then all you do is disconnect the wiring harness and unscrew like you would a bolt.
If you need a video to explain then you can google or utube it.
Jun 20, 2009 at 5:02 AM
