1998 Plymouth Breeze loosing Coolant
1998 PLYMOUTH BREEZE
350,000 MILES • 4 CYL • FWD • AUTOMATIC
RANIMCI
Hi I have a '98 plymouth breeze and everytime I look under the hood my coolant seems to be really low in the reservoir. There has never been any on the ground under the car so I am unsure where it is going. Oil was changed recently and besides dirty it was fine. I have had the belts, spark plugs and power steering pump replaced in the last year. It also stalls when I accelerate and let go of gas fast. I only paid $750 for it just over a year ago. Is it worth fixing or should I just cut my losses? Thanks Ranita
Oct 29, 2010 at 5:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the acceleration issue could be from dirty fuel filter, as for the coolant loss i would not let that go it needs fixed. check the transmission fluid to ensure its not leaking into that. do you notice any smoke from exhaust?
Oct 29, 2010 at 8:58 AM
RANIMCI
I haven't noticed any smoke from the exhaust. i will get the transmission fluid checked though.
Oct 29, 2010 at 11:00 AM
