1998 Plymouth Breeze Irregular shifting
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
BJUSTICE
It will shift fine then sometimes stick in a lower gear! Also, the automatic downshift is harsh, even to the point the tires will squeel. Any thoughts?
Jan 4, 2008 at 12:37 AM
2CARPRO JACK
  • 11,533 POSTS
Check engine light on? might want to have it scanned to see if the PCM stored any codes pertaining to the transmisison. If not light it could be a mechanical problem which would require a trip to a trans shop
Jan 4, 2008 at 9:56 AM
