1998 Plymouth Breeze Ignition
1998 PLYMOUTH BREEZE
77,770 MILES • 4 CYL • 2WD • AUTOMATIC
HALUSKA33
My car will not start the next day. 4 times i jump start the car it jumps fast even without the other car not on. I drive the car long ways and overnight when i get into my car it will not start. I took it to the shop and all the mechanic did was clean it but it still will not start. Where are the ignition cables located someone said to try put in a new ignition cables?
Oct 21, 2008 at 7:47 AM
Hi haluska33 and welcome to 2carpros
Do you mean it cranks over and refuses to start or just plain no engine crank at all, please explain more about the situation
No cranking can involve the fuse no.8 20amp ignition switch,transaxle range sensor starter relay, and starter itself.
Oct 21, 2008 at 8:26 AM
HALUSKA33
i start my car ok in the morning i drive few hours then i come home, next morning it would not start, I had to jump battery, starts quickly. i drive few hours
went shopping got in car, it would not start again, someone had to jump battery again, the mechanic says battery is Ok, he cleaned battery the problem is the BATTERY OR MOTOR WOULD NOT CRANK WHEN I TRY TO START. JUST DEAD EVERY TIME I TURN THE ENGINE OFF.
Oct 21, 2008 at 1:03 PM
ZACKMAN
  • 4,202 POSTS
If the car starts right away while being jumped, the problem will lie either with the battery or the cable from the battery to the jump posts. If you remove the air cleaner box, you will see the battery cables run from the jumper posts to the battery.
Have your mechanic take out the battery from the fender well, and do a load test on it. I have a feeling that your battery does not hold charge.
Oct 21, 2008 at 1:30 PM
