1998 Plymouth Breeze Fuse
112,000 MILES • 4 CYL • FWD • AUTOMATIC
RUDI
I have a 1998 Plymouth Breeze that keeps blowing a 20 amp mini fuse that is in the starter circuit. What could be causing this. The first time it blew the I suspected a bad starter and discovered that it was the fuse before I removed the starter. I replaced the fuse and it lasted about one week before it blew again. Is there something else on that circuit that is bad or is it the starter? The fuse blows all the time now and the car will not start. It blows when i turn the key to activate the starter, sometimes it blows when the starter is cranking. Do I need a new starter and if I do how do I get to it to remove it? Thank You
Rudi
Dec 5, 2007 at 12:11 PM
BMRFIXIT
  • 19,053 POSTS
[quote:d58287bfb6="Rudi"]Electrical problem
1998 Plymouth Breeze 4 cyl Front Wheel Drive Automatic 112000 miles
Rudi[/quote:d58287bfb6]
its your starter
go for it get new one
Dec 16, 2007 at 6:36 AM
