1998 Plymouth Breeze Dash lights and Rear running lights ou
1998 PLYMOUTH BREEZE
130,000 MILES • 4 CYL • FWD • AUTOMATIC
INDYCART
I have a issue that i have lost the dash lights and rear running tailights. Brake lights work fine. Checked fuses all seems fine.... Any suggestions would be great
Thanks
Feb 7, 2008 at 5:14 AM
JAY.TRAN
  • 9 POSTS
[quote:1332d4fbc2="indycart"]Electrical problem
1998 Plymouth Breeze 4 cyl Front Wheel Drive Automatic 130000 miles
Thanks[/quote:1332d4fbc2]
I'm goin thru a no Brake light issue now....
I noticed in the fuse block under the hood near the Battery terminals. Open the cover and there is a fuse for dash/tail lights.
Check it out
Any thoughts on no brakes??
I'm about to go out and look at the pedal switch. That the only thing I have not checked yet
Feb 10, 2008 at 6:47 AM
