Steering problem
1998 Plymouth Breeze 4 cyl Front Wheel Drive Automatic
when steering right makes a goaning noise and vibrates through car tie rod ends have ben replaced and cv joints
Wednesday, March 24th, 2010 AT 3:02 PM
LEGITIMATE007
MECHANIC
That has to do with your power steering, usually the problem is a week waterpump, meaning the part of the pump that forces the fluid foward has worn down and doesnt do it effieciently anymore. Does this happen even when you turn the wheel while in park or neutral?
