1997 Plymouth Breeze Turn Signal Flasher
16,000 MILES • 4 CYL • FWD • AUTOMATIC
RICH.WRIGHT
Where is the turn signal flasher located on a 97' Breeze?
Feb 2, 2010 at 8:41 AM
  • 75,988 POSTS
1997 Plymouth Breeze L4-2.0L VIN C Combination Flasher Location
https://images.2carpros.com/forum/automotive_pictures/12900_tsf_1.gif
COMBINATION FLASHER The flasher is mounted to the back side of the multi-function switch. To gain access the upper steering column cover must be removed. Refer to Steering and Suspension/Steering/Steering Column Cover removal procedures. The flasher can be removed by pulling it forward. The flasher is serviced separately from the multi-function switch. The flasher is black in color for ease of identification.
Feb 2, 2010 at 8:50 AM
